Concatenate values within the same cell & space
  • Mar 13, 2024 8:24 PM UTC
  • 152 views
galigis
Forum|alt.badge.img+22
Hi All,
I need to concatenate the two values of the same cell into just one line. I’ve been (partially) able to do it by using a StringReplacer but some of the cells show an space which make the StringReplacer not working, see below an example:
There’s an space between line 2 and Siding, how can I make the final result ‘CE Siding’ ?
Best answer by nielsgerrits
Thanks @nielsgerrits but still doesn’t do what I need, see below the parameters used:
The value at row 6 still shows an space between 2 and Siding
Try to copy the value you need to replace and paste it in the StringReplacer, no regex?
nielsgerrits
Forum|alt.badge.img+67
StringReplacer, regex, replace \n
galigis
  • Mar 14, 2024 10:08 AM UTC
The value at row 6 still shows an space between 2 and Siding and also a Carrier Return
nielsgerrits
  • Mar 14, 2024 10:32 AM UTC
galigis
  • Mar 14, 2024 10:42 AM UTC
It worked! :)
