Compactness of landuse plan in ArcGis
  • May 14, 2018 3:20 PM UTC
  • 43 views
Want to analyse compactness of Landuse Plan. suppose each rectangular polygon has 8 neighbors. I want to analyse which polygon has same landuse neighbors. for example say residential is a polygon, so i want to know that from his 8 neighbors how many have same landuse (Residential) and how many don't have same landuses. Please see the following picture.,I am working on Landuse change methodology in Transit oriented development.
I think SpatialRelator transformer will give you the results you need. For each area, it will return a list of all the neighbors that touch. You can then use the list trasnformers, like ListHistogramer, to analyse the results. If you include a sample dataset I can probably give you a proof-of-concept.
