Combine shapes from different windows submaps to one DWG
  • Jul 19, 2017 9:55 AM UTC
  • 93 views
jpdenboer
I have multiple shapefiles in different windows submaps and I want to union them to one dwg file. I tried Workspacerunner but without success. Is there another solution?
lars_de_vries
Forum|alt.badge.img+10
Hi @famjpdenboer,
from your question I cannot define what your real problem is. If you have multiple Shapefiles in different Windows submaps, you can select them using the Select Multiple Folders/Files option at the parameter.
Figure 1. Select Multiple Folders/Files option
In don't know how you designed the workspace you are calling in the WorkspaceRunner, but with DWG-files there is no option to Insert features into an existing DWG, so having another shapefile will probably overwrite your DWG.
If this is not the solution you are looking for, I would like to request you to eleborate a bit more on the nature of the issues you are running into.
jpdenboer
  • Jul 19, 2017 10:26 AM UTC
Hi @famjpdenboer,
Thank you very much! The solution is sometimes easier than you think
