color balance and mosaic several images
  • May 19, 2015 5:45 AM UTC
  • 130 views
I'm looking to process about ten large ECW files, these need to be color balanced all together so it's as seamless as possible.
In terms of the color, some tiles might be brightness changes, others need color tints
As a possible method, I was thinking if I manually picked a point to white balance in each file then perform cell value manipulation based on the RGB differences. I suspect it will be an average output though.
I'm not sure what transformers to be using. In photoshop its an intuitive slider available but I've not seen something in FME.
I could really do with ideas, transformers or processes on how to handle the color balancing. Thanks.
Best answer by david_r
Hi
Look at this article, in particular under the heading Color Correction:
https://knowledge.safe.com/articles/Samples_and_Demos/Examples-using-the-RasterExpressionEvaluator-Transformer
David
  • May 19, 2015 12:35 PM UTC
Hi
David
