CityGML: change gml_geometry
  • May 29, 2018 2:46 PM UTC
  • 81 views
Hello everybody,
I'm using this template https://hub.safe.com/templates/citygml-create-solitaryvegetationobject-with-implicit-representation to create a CityGML file that contains trees as SolitaryVegetationObjects with implicit representation. The template works fine but doesn’t serve my purpose as I want to use the data in the 3DCityDB which doesn't support MultiGeometry features. Is there a way to change the gml_geometry?
Thank you for your help.
Best answer by daveatsafe
Hi @lsdanger,
You can change the geometry of the tree models before adding them to the shared item library. Please add a GeometryRefiner transformer right after the tree model input. This will change the output gml_geometry to MultiSurface.
If you follow the GeometryRefiner with a GeometryCoercer, set to fme_composite_surface, the gml_geometry will become a CompositeSurface.
daveatsafe
Forum|alt.badge.img+24
  • May 29, 2018 4:12 PM UTC
Hi @lsdanger,
