CityGML - ADE - problem in nested feature attributes
  • Oct 9, 2014 5:32 PM UTC
  • 0 replies
  • 31 views
Hi all,
I have a question. and one problem!
I have a CityGML file with lots of generic attributes. On the other hand I have CSV file containing all these generic attribute names and their values.
What I need to do is a validity check for these generic attributes. Like if all obligatory attributes are given as generic attributes and if the assigned values are in the range.
My question is:
Is it possible in FME to filter feature's attributes based on attribute names like having only those attributes which do not contain citygml in their names?!
My problem:
I am going to write a citygml file into CityGML ADE-inspire. (I have the schema for the ADE)
My problem is regarding the nested feature attributes. I mapped every things correctly and when the output is redirected to FME inspector the results are OK but when I need to write it in a gml file the inspire attributes (list ones) are missing.
Example:
In attribute creator I have:
core3d_inspire_id{0}.base_identifier_base_namespace
core3d_inspire_id{1}.base_identifier_base_namespace
In the writer the corresponding attribute is:
core3d_inspire_id{}.base_identifier_base_namespace
this causes the problem because FME doesn not understand that those 2 (list)attributes ({0}/{1}) should be written as core3d_inspire_id{}.base_identifier_base_namespace.
has anybody idea how can I solve the problem?
Thank you in advance.
Mani
