Can I write to a Enterprise Geodatabase (SDE) that is not running?
  • Sep 6, 2017 8:54 PM UTC
  • 77 views
fmelizard
Forum|alt.badge.img+22
I have an enterprise geodatabase, but no SDE services running. Can I use the sde writer to write to it?
Best answer by richardatsafe
Yes, you can write to a sde database where the sde service is not running by using GEODATABASE_SDE writer and pointing to a sde connection file. The legacy SDE30 writer, on the other hand will not be able to write to your enterprise geodatabase if your sde services are not running.
richardatsafe
Forum|alt.badge.img+11
  • Sep 6, 2017 8:58 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Sep 6, 2017 9:09 PM UTC
I believe the question is a bit off:
The database needs to be up and running, the SDE services that connect ArcGIS to the database do not need to be running. The connection can be made by FME.
