Can i read arcsde with a arcgis engine license?
  • Oct 23, 2017 2:36 PM UTC
  • 33 views
I have a old version of arcgis (10.0) and need to connect to arcsde 10.2. This connection used to work but after a oracle upgrade on the server no longer works. My supplier tells me that i now need to upgrade my arcgis version to match, i don't want to buy a new arcgis but i do have access to arcgis engine 10.4. Can i use this to enable the a sde connection in FME?
  • Oct 30, 2017 3:36 PM UTC
According to this article, yes, you can read from an ArcSDE Geodatabse using an ArcGIS Engine license:
