BADNEWS autocadCorrTemplate.fmi could not be opened
  • Jun 18, 2018 9:28 AM UTC
  • 80 views
jatoxa
Forum|alt.badge.img+12
When running a workspace on Cloud I get the following error "BADNEWS: File /opt/fme-engine-2018/metafile/autocadCorrTemplate.fmi could not be opened (foundation/framework/engine/tabrdr_classic.cpp:2756 - open) - (foundation/framework/engine/tabrdr_classic.cpp:1460 - getRow)"
The same workspace works fine in Workbench and even worked on Cloud in an earlier iteration. I have recently updated the workspace and it does contain a DWG reader but I have made no changes to that part of the workflow.
Best answer by erik_jan
Still quite a bit of BADNEWS messages around that can be ignored if they do not break the workflow.
See this idea: clean up the badnews messaging
erik_jan
Forum|alt.badge.img+26
  • Jun 18, 2018 1:19 PM UTC
@j2
Is there any other symptom indicating that your workspace did not run successfully?
As mentioned by @erik_jan, as long as there is no other symptom than the BADNEWS log, it can be ignored in a lot of cases.
