Automate ArcGIS Online Writer Parameters
  • May 15, 2018 7:16 PM UTC
  • 43 views
dkirouac
Forum|alt.badge.img+5
Is it possible to use input from a .csv file to populate the service and layer parameters in an ArcGIS Online writer?
lars_de_vries
Forum|alt.badge.img+10
Currently it is possible to set the layer with an attribute. However it is not (yet) possible to set the service directly with an attribute. You could add an idea to support this functionality.
  • May 17, 2018 7:39 AM UTC
I often do something similar using private scripted Python parameters that read the CSV (or INI, JSON, etc) during FME startup and then feeds the value(s) to e.g. a writer.
I'm sure you'll find some examples here if you search around.
