AutoCAD multilinetext width?
  • Dec 29, 2014 11:03 PM UTC
  • 61 views
Is there any way to determine the width (in coordinate units) of AutoCAD multiline text output?
I need to offset the text to the left for callout tags where the leader line leans to the left of the item they are describing (subtract width amount from x coordinate) - but I have yet to figure a way to extract the "rendered" width of the longest line to do so.
  • Dec 31, 2014 9:46 PM UTC
If this is not possible - what is a good way to calculate the longest line (in number of characters) so I can just use that and mutiply by an average width to get close?
  • Jan 5, 2015 10:03 AM UTC
have you looked at the StringLengthCalculator?
David
gio
Forum|alt.badge.img+15
  • Jan 7, 2015 1:12 PM UTC
SLC is in bytes, is it not?
I use boundingbox on the text attribute and extract its dimensions.
You need to (trial and error) adjust the value somewhat.
It is very dependant on the font type.
Look:
creates:
and zoomed in:
There is a tcl/TkCmd Font (wich has for instance Measure function) Wich is in pixels tough.
