AutoCAD Map OD Writer
  • Apr 19, 2018 11:54 PM UTC
  • 96 views
Converting from SQL to AutoCAD Map 2018 with the OD writer. I've exposed both the autocad_map_odtable and autocad_layer format attribute then created the correct values. Everything looks good as far as primary OD Table Name and Layer Names.
Except that I get the OD Table Name set through the exposed format attribute in addition to a OD Table Name for each of the new layers defined.
My understanding was that by exposing setting both the layer and OD Table format attributes that the writer would suppress or only create on OD Table name?
Best answer by hlouie
In the writer, what is your parameter for Object Data Table or Layer Name?
The example below is the Object Table Name = fme_feature_type, AutoCAD Layer Name is different
  • Apr 19, 2018 11:56 PM UTC
My understanding was that by exposing setting both the layer and OD Table format attributes that the writer would suppress or only create one OD Table name?
hlouie
Forum|alt.badge.img+17
  • Apr 20, 2018 9:37 PM UTC
  • Apr 20, 2018 9:58 PM UTC
thanks hlouie,
I had multiple feature writers in the work space as soon as I remove them then the workspace created one od table and passed the correct layer names for each of the subtypes.
Thanks for your help
