Autocad map od reader entity id attribute being dropped
  • Apr 15, 2020 4:28 PM UTC
  • 59 views
I have a workbench that I have been using for several days. all of the sudden when I open the workbench it will not run. I discovered that the reader does not show the exposed autocad_od_entity_key available any longer.
if i go to a new workbench and pull in the same data the field does appear.
i open a workbench that last successfully ran and then i did a saveas. in this workbench also the reader does not allow the od_entity_key value.
if i attempt to update the reader the od data table feature is completely dropped!
