AUTOCAD Format Attributes or Transformer?
  • Apr 28, 2020 5:03 AM UTC
  • 43 views
franco69
Forum|alt.badge.img+11
Hi Guys
I don't know if i should open a new task but i do so now.
I have 2 short answers
Reader: dwg
my output dwg should be rotated (another north direction) and scaled to 1:1000
are there format attributes for that or have i handle this with Transformer (Scaler,....)
thx and Greetz
Franco
itsmatt
Forum|alt.badge.img+48
  • Apr 28, 2020 6:19 AM UTC
You will have to use Transformers for this I'm afraid. I would note though that this might not be as easy as you're hoping. If you want your DWG to look like your input i would suggest that you actually find another tool to do this.
Can you just use a viewport in AutoCAD?
Or perhaps this AutoCAD post will help: https://forums.autodesk.com/t5/autocad-forum/rotating-the-view-in-model-space/td-p/2652938
Good luck!
