AutoCAD 2021
  • Jul 22, 2020 3:39 PM UTC
  • 29 views
The reader documentation for acad list 2020 as the most recently supported version, just checking in to see if this is true for the FME 2020.1 release and when AutoCAD 2021 will be supported.
jovitaatsafe
Forum|alt.badge.img+11
Hi @nfink,
Thanks for your question! We haven't officially tested it yet for Autocad 2021, but the format spec should still be unchanged enough that FME should be able to load DWG files authored in Autocad 2021 with either the DWG or the RealDWG readers. Please let us know if you run into any snags with it and I'd be happy to take a closer look.
