Are Cesium 3DTiles already DRACO compressed?
  • Jul 30, 2024 5:44 AM UTC
  • 237 views
oliverwesp
Participant
Forum|alt.badge.img+3
I currently work with the Cesium 3DTiles writer and stumpled upon some requests asking for support for the DRACO compression.
I tried to do apply the compression afterwards using ‘3d-tiles-tools’ with no luck. So I took a deeper look on the b3dm Files using ‘3d-tiles-tools analyze’ and it looks to me like it’s already DRACO compressed.
‘3d-tiles-tools analyze’ gives me:
"asset": {
"generator": "FME 2022.2.5.0",
"version": "2.0"
"meshes": [
"primitives": [
"attributes": {
"_BATCHID": 4,
"NORMAL": 2,
"POSITION": 1,
"COLOR_0": 3
"indices": 0,
"material": 0,
"mode": 4,
"extensions": {
"KHR_draco_mesh_compression": {
"bufferView": 0,
"attributes": {
"_BATCHID": 3,
"POSITION": 0,
"NORMAL": 1,
"COLOR_0": 2
"scene": 0,
"extensionsUsed": [
"CESIUM_RTC",
"extensionsRequired": [
"CESIUM_RTC",
Can somebody confirm that the Cesium 3D Tiles writer is already doing DRACO compression? Or am I missing something?
best regards,
Oliver
Best answer by itsmatt
Yes, the extension present suggests draco compression is already in use.
One thing which you can do is to use 3d-tiles-tools to decompress and then recompress. You might find that the compression is better. I’ve seen this in the past.
Draco compression was added I think with FME 2021 or FME 2022.
itsmatt
Forum|alt.badge.img+48
  • Jul 30, 2024 6:27 AM UTC
