ArcSDE Connection File not updating in ESRI GDB(SDE) Reader
  • May 12, 2017 7:01 PM UTC
  • 48 views
ngstoke
Hello FME users,
I've added a new SDE connection in my Database Connections but my connection file path inside the Esri Geodatabase (ArcSDE Geodb) Reader parameters is still showing my old connection file.
I've already deleted it from my ArcCatalog folder. I'm having to click on the (...) button and select the new connection file.
Anyone else have this issue, and any thoughts on how to get the new file path to show up?
Thanks in advance.
  • May 17, 2017 2:28 PM UTC
Is it possible that this file was set as default?
Try updating the filename, then setting it as default using the "Default"-button at the bottom of the dialog.
