ArcGIS 10.05 and FME 64 bit
  • Nov 26, 2013 9:38 PM UTC
  • 45 views
Hi All,
I hope I can explain my issue properly.
1) We upgraded our PCs to Windows 7 (64bit) and upgraded FME 2013 SP4 64bit and using  ArcGIS 10.05, (natively 32bit) (Desktop, Engine etc)
2) We have large number of workbenches with writers using FILE_GEODATABASE (ArcObjects).
3) When I run my existing workbenches I get the following error messages;
“Unable to perform any licensing related tasks. This is a 64-bit version of FME which requires a 64-bit version of ArcGIS Server
A fatal error has occurred. Check the logfile above for details”
4) I changed my writers to use the  file geodatabase (API) and all seem to run fine.
Questions;
a) Are there any  issues with switiching my writers to use the file geodatabase (API)?
b) Any ideas on how to batch change my writers from GEODATABASE_FILE (ArcObjects) to use the FILEGDB (API)?
Thx in advance,
Ken
  • Nov 27, 2013 7:55 AM UTC
generally speaking, it is much easier to use 32-bit FME with ArcGIS products, so I'd recommend that if possible.
See also this page for more details regarding compatibility between FME and ArcGIS products.
David
