AGOL writer
  • Jan 31, 2020 2:18 AM UTC
  • 48 views
Hi there,
I am using AGOL writer to insert the data into a feature layer. I noticed that whenever I ran the transformation, it insert the data into a feature layer. I wanted to set AGOL writer in such a way that when I run the transformation, it deletes the existing data and insert the new one. Could anyone guide how to do that? Please note that the data on FME transformation does not have OBJECT_ID attribute.
Best answer by oscard
In the Writer you have to change the parameter "Truncate First" to "Yes"
oscard
Forum|alt.badge.img+23
  • Jan 31, 2020 6:53 AM UTC
