AGOL reader issue FME 2018.0
  • May 8, 2018 2:40 PM UTC
  • 132 views
divil
Hello,
I've installed FME Desktop 2018.0 Database Edition.
When I open an existing FME Workspace with a AGOL Reader I get the following error when I run it:
ArcGIS Online Feature Service Reader: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was 'HTTPSConnectionPool(host='www.arcgis.com', port=443): Max retries exceeded with url: /sharing/generateToken?f=json (Caused by ProxyError('Cannot connect to proxy.', error('Tunnel connection failed: 407 Proxy Authentication Required',)))'
If I try to add a Web Connection to my AGOL Account; after I enter my authentication details I get a error
I am going through a proxy server.
Any ideas?
Thanks Helen
divil
Sorry meant to include I can log into my AGOL account on the same box in Chrome.
divil
  • May 8, 2018 3:39 PM UTC
Issue seems to be resolved.
I saw this post: https://knowledge.safe.com/questions/44922/getting-the-error-python-exception-no-module-named.html
I didn't seem to have the files mentioned in it on my server, but I deleted a folder C:\\apps\\fme and I can now successfully use an AGOL Reader. Haven't tested the writer yet.
divil
  • May 9, 2018 8:36 AM UTC
Was able to connect to AGOL in FME 2018.0 last thing before I left work yesterday evening, come in this morning and it is not working again. This is head melting stuff. I don't this version is reliable for scheduled updating of AGOL feature services.
divil
  • May 30, 2018 11:31 AM UTC
Eventually got his issue resolved with a change to our proxy server, we had to whitelist arcgis.com and set the policy to 'By Pass Filtering and Authentication' .
The proxy was allowing access through Chrome and ArcMap Desktop, but was causing trouble when reading/writing in FME.
