Adding related candiate attribute as CSV in the requestor data
  • Oct 11, 2015 11:51 AM UTC
  • 67 views
How to add the result of the spatial relator as CSV in the data of requestor
  • Oct 11, 2015 12:23 PM UTC
Extract your required element(s) from the "_relationships{}" list which is contained by each output feature from the SpatialRelator.
Takashi
  • Oct 12, 2015 11:35 AM UTC
I need to join the requestor feature to supplier feature as CSV in a field on the requestor data e.g.
If I have a requestor record joined with 3 supplier a,b and c then the output should be
RequestorName , RequestorId , SupplierDetails
khalid                , 5                 , a,b,c
  • Oct 12, 2015 11:40 AM UTC
so then, the ListConcatenator might help you.
