Accessing file geodatabase on ArcGIS portal
  • Feb 18, 2020 4:00 PM UTC
  • 0 replies
  • 24 views
waterbeemds
Forum|alt.badge.img+9
Hello,
I have a file geodatabase on ArcGIS portal. In need to access it's contents without downloading the file geodatabase. I tried to approach the file geodatabase with the ArcGIS Portal feature service reader but as designed the file geodatabase did not show up as a readable feature class.
I am looking for a method to read the contents of the file geodatabase as if I would do normally with the file geodatabase reader. Is it even possible to read from a file geodatabase on ArcGIS portal with FME?
Thanks for the help!
