400 layers to any format via FME Server...
  • Sep 19, 2013 3:09 PM UTC
  • 40 views
What is the best approach for creating an FME workspace that will accept a layer name as a parameter, then export to any data format.  The layers will be coming from SDE, however, depending on the layer name, may have additional FME transformers, etc.  Is there a way to conditionally evaluate a layername parameter, then branch off the workspace execution?  For the output, I assume the generic writer is my best bet?
Thanks in advance,
M
Best answer by mapsrus
FYI - Use Creator, FeatureReader, ParameterFetcher.  Works like a charm.
  • Sep 20, 2013 4:03 PM UTC
