I’m encountering this error and am at a loss. Everything in workbench (SQLCreator - Attribute Mgr - Excel Writer) seems to work fine, up until it gets to the writer.
Excel Writer: Failed to write an attribute of type 'string' with value 'XMLDATA' to row '0' column '-1015942868'. Error message is 'col must be in range 0-16383'. Skipping feature
Writer Mode: Update
Output Field Names: Yes
Formal Field Names: No
Use Attribute Names as Column Positions: Yes
Start Position: Start Column: 1 Start Row: 1
Any suggestions?
