Zipping a file but not creating a folder inside the zip
  • Jul 17, 2019 2:41 PM UTC
  • 89 views
oliver.morris
Forum|alt.badge.img+14
Hi, I pull down a file from s3, zip it then upload it to s3 again.
When I use the zip archiver it adds the file to a folder and zips up the folder which has the same name as the file.
This is a little of a pain when extracting. Is there anyway to zip just the file without having a folder.
Many Thanks
Oliver
stalknecht
Forum|alt.badge.img+22
  • Jul 23, 2019 7:05 AM UTC
When I use the ZipArchiver there is no extra folder created when I archive a file. Are you copying a folder and/or are you using FME server?
nathanatsafe
Forum|alt.badge.img+9
Hi @olivermorris,
Depending on your workflow and output format you could potentially make use of a fanout expression. Take a look at this FME Evangelist tweet for more info. A dataset fanout should write zipped files into an unzipped directory.
Hope this helps,
Nathan
oliver.morris
  • Jul 23, 2019 3:50 PM UTC
thank you both, turns out the new s3 connector tricked me with folder vs filename. It is now working without creating a folder. Thanks but this was as usual user error!
Oliver
