Z coordinate from field value.
  • Jan 2, 2021 5:00 PM UTC
  • 515 views
Hi everyone,
I have a points shape (.shp with Z value) that contains a field with measured Z-values (called Zvalue and is a float), which I copied from a different point shape in my workbench.
The idea is that the Z value (the coordinate) is set to the value in it's Zvalue field.
Does anyone know how this is done in FME?
Best answer by jlbaker2779
Use a 3dForcer and set the Z value as the elevation. That will turn them into 3d points.
  • Jan 2, 2021 5:48 PM UTC
  • Jan 3, 2021 7:29 PM UTC
Thanks for the answer!
3D forcer was indeed the best option to force the Z-value to a attribute.
