XMLTemplater: Adding XML attributes to Sub Templates "ports"
  • July 13, 2015
  • 87 views
I am successfully using the XMLTemplater/XMLFormater approach to write to a TEXTLINE writer.  My question is about adding attributes to the top level "port".  A configuration like this (PROJECT) reads in template files based on user parameters:
Using a template like this:
<Project name="{fme:get-attribute("fs_project_name")}" type="Asset">
    <AssignedTo>"{fme:get-attribute("fs_assigned_to")}</AssignedTo>
    <ScheduleDate>{fme:get-attribute("fs_schedule_date")}</ScheduleDate>
    <DueDate>{fme:get-attribute("fs_due_date")}</DueDate>
    <ComplianceDate>{fme:get-attribute("fs_compliance_date")}</ComplianceDate>
    <UploadStatus>InBasket</UploadStatus>
    <Location>
        <Geometry type="undefined"/>
        <OriginalGeometry type="undefined"/>
    </Location>
    <Attributes>
        <Attribute id = "InspectionType">Asset</Attribute>
    </Attributes>
</Project>
Results in this (You can see that the <Project> tag is repeated.
<Project>
<Project name="T00123456" type="Asset">
<AssignedTo>"204052230</AssignedTo>
<ScheduleDate>2015-07-08</ScheduleDate>
<DueDate>2015-07-08</DueDate>
<ComplianceDate>2015-07-08</ComplianceDate>
<Location>
<Geometry type="undefined"></Geometry>
<OriginalGeometry type="undefined"></OriginalGeometry>
</Location>
<Attributes>
<Attribute id="InspectionType">Asset</Attribute>
</Attributes>
</Project>
</Project>
My work-around is to use a couple of StringReplacers to remove the superfluous tags but I was wondering if there is a more elegant way.
Thanks in advance.
Best answer by fmelizard
I would check if the project tag exists in the root template. If that is the case try removing it.
Hope this helps.
fmelizard
Forum|alt.badge.img+22
  • July 14, 2015
Hope this helps.
  • July 14, 2015
I looked everywhere but the root template.  I was following an example from a tutorial and thought that the root XML needed to have references to the named sub-template ports using tags.  I know that these are refrences with {fme:process-features("")}.  The perils of cut-and-paste.
Thanks for pointing me the right direction.
