XML Templater: create more placemarks (point and line) in a root template
  • Oct 30, 2017 2:46 PM UTC
  • 84 views
Hello,
I'm trying to create a kml-file using the xml-templater. In the kml file I want to visualize points and Lines, something like:
<Placemark>
<styleUrl>#Icon</styleUrl>
<Point>
<coordinates>{fme:get-attribute("rw_wgs84")},{fme:get-attribute("hw_wgs84")}</coordinates>
</Point>
</Placemark>
<Placemark>
<LineString><coordinates>{fme:get-attribute("_coordinates")}</coordinates></LineString>
</Placemark>
But I get an syntax error (missing comma between the Placemarks)?
What Am I doing wrong? How can I create a template for different placemarks?
Thanks for your help,
Isabell
  • Oct 30, 2017 3:38 PM UTC
For repeating tags such as multiple instances of Placemark, I'd recommend using the sub-templates and not the root template.
I recommend the help for the XMLTemplater, it's really thorough and covers a lot of use cases.
  • Oct 30, 2017 10:14 PM UTC
Hi @isi, an XML template expression can return a single XML element or a single sequence that contains multiple XML elements, and comma separated multiple XML elements can be considered as a sequence. Since you are going to create two <Placemark> elements (i.e. sibling elements without parent), you will have to separate them with a comma.
Note that the result will be just a string containing two <Placemark> elements, and it cannot be treated as a single XML fragment in the subsequent process.
  • Nov 6, 2017 11:30 AM UTC
Thank you for your answer! Now it works!
Thank you for your anwer! Now it works!
