write xml elements only if a feature attribute has a value
  • Nov 19, 2020 8:04 AM UTC
  • 0 replies
  • 38 views
nicolae.soare
Forum|alt.badge.img+7
hello,
I am trying to write inside an xml file elements only if a feature attribute has a value.
I have 2 shp files :
In first file I have "Eticheta" feature with names of the street.
In second file I have "label" feature with attributes values are the same as "Eticheta " from the first file. Here, in the second file I have also "NR" which.
I am trying to write in XML numbers for streets and I need to write the numbers on each street.
I used an if-then-else statement that writes out the numbers only if street from first file is exactly like street from second file.
in my XMLTemplate, in subtemplate I have:
{ if( fme:has-attribute({fme:get-attribute("label")}) eq fme:has-attribute({fme:get-attribute("Eticheta")}) )
then
{fme:process-features("ADRESA")}
but fails to write data inside xml file.
errors from log:
XMLTemplater (XMLTemplaterFactory): An error occurred while parsing the 'ADRESE' sub-template
XMLTemplater (XMLTemplaterFactory): A fatal error has occurred. Check the logfile above for details
Can you please help me with this issue?
Thank you.
Nicu
