write DGN with custom linestyles
  • Nov 21, 2017 10:14 AM UTC
  • 73 views
Hey there,
I'm trying to write a v8 DesignFile with custom linestyles but I don't know which parameter to set for success.
The line style is already copied into the referenced seedfile and I tried setting parameter igds_style to for example 'Line A' (which is name of the style), then I tried using DGNStyler transformer to set style, but non of that worked. According to documentation I'm not allowed to set the styles name with v8, I tried the internal style-ID but without success.
Does the custom line styles have to be part of the attached resource-font-file or of the seedfile? And do I have to set igds_*-Parameters or use DGNStyler or is using both together breaking each other?
(I'm using Desktop 2016.1 here)
Thanks in advance,
Maik
Hi @maikhertel
please take a look at this article in FME documentation: http://docs.safe.com/fme/2016.0/html/FME_Desktop_Documentation/FME_ReadersWriters/igds/Custom_Line_Styles.htm The article explains how to deal with custom linestiles (custom linestyle libraries, seed-file preparation, style assignment).
