WorkspaceRunner and variable
  • Nov 5, 2024 11:00 AM UTC
  • 8 replies
  • 195 views
olivierl
Forum|alt.badge.img+3
Hello,
I would like to test a variable before running a workspaceRunner or not.
if attribute ‘recetteCouche’ = 1 then running workspaceRunner ‘000_recetteCouche..’0’ else if attribute ‘ecritureLivrable’ = 1 then running workspace ‘0000_ecritureLivra...’, etc
my configuration for each  WSR is : ‘wait job job to complete = YES’
Please, someone have an idea ?
Olivier.
Best answer by bwn
Lots of different ways.  Basic way of Prioritising and running a Workspace with a dynamic value for its Path below.
Sample Excel data.
Feeds into a Prioritisation using Eg. Sorter and Sampler.
tomfriedl
Forum|alt.badge.img+14
  • Nov 5, 2024 11:44 AM UTC
You can use a Tester or TestFilter before the WorkspaceRunner.
olivierl
  • Nov 5, 2024 2:44 PM UTC
Thanks but you can imagine i tried it before without successing
tomfriedl
  • Nov 5, 2024 2:53 PM UTC
Where are the attributes to filter? You use only the Creator before the WorkspaceRunner.
olivierl
  • Nov 5, 2024 4:26 PM UTC
This is an excel file with  an attribute for each workspace Runner set to true or false
bwn
Forum|alt.badge.img+26
  • Nov 6, 2024 5:20 AM UTC
Sample Excel data.
olivierl
  • Nov 6, 2024 6:52 AM UTC
Great ! works perfectly
Thanks a lot
olivierl
  • Nov 6, 2024 7:00 AM UTC
i completed with :
  • ‘tester’ for run = 1
  • set sampling Rate (N) to the max of ‘controle’
  • included user parameters in to workspace (even if few of the 10 .fmw don’t need all)
Meaby an other way to do it but this one works
Thanks again
olivierl
forgot this
