Working across Different tables
  • August 14, 2017
  • 6 replies
  • 68 views
I have data stored across multiple DBF files.
DBF1 contains data stored as follows (sample):
ID ---------DEMAND-------PATTERN
1123-----------5---------------0.3455
3456-----------3---------------0.3212
2322-----------2---------------0.2112
DBF2 contains data stored as follows (sample):
ID----------------ZONE
1123------------ZONE1
3456------------ZONE2
2322------------ZONE1
TOTAL_DEMAND for a particular zone is calculated as the sum of products of the demand and pattern for all the ID that lie within that ZONE.
Ex. for ZONE1(which contains 1123 and 2322), TOTAL_DEMAND= 5*0.3455+2*0.2112
I need to create the final results tabulated as follows:
ZONE-------------TOTAL_DEMAND
ZONE1-----------(calculated as above)
ZONE2-----------(calculated as above)
The task is easier with VLOOKUP in excel, but I am not able to find suitable transformers to do the same in FME. Please suggest a suitable method.
Suggestions regading use of a programming language(such as python) to achieve the same are also welcome.
PS- Hiphens (-) are added just to give clarity about the data arrangement
Best answer by takashi
If you are familiar with SQL statements, the InlineQuerier could also be a choice. e.g.
select
    a.ZONE,
    sum(b.DEMAND * b.PATTERN) as TOATL_DEMAND
from DBF2 as a
inner join DBF1 as b on b.ID = a.ID
group by a.ZONE
fmelizard
Forum|alt.badge.img+22
  • August 14, 2017
Hi @amitaman001,
I suggest you try using the FeatureMerger of DataBaseJoiner to merge the data based on ID. This will then enable you to easily use either an ExpressionEvaluator or AttributeCreater to create a new TOTAL_DEMAND attribute based on the math above.
erik_jan
Forum|alt.badge.img+26
  • August 14, 2017
Hi @amitaman001
I would use a StatisticsCalculator on DBF1 to calculate the TOTAL_DEMAND (group by ID): use the Sum calculation and remove all other output..
Then use the FeatureMerger to join DBF2 based on ID = ID.
That should get you the required output.
danilo_fme
Forum|alt.badge.img+57
  • August 14, 2017
Hi @amitaman001,
I created a template file using .xls like Reader.
How can you see, i used first the transformer FeatureMerger by attribute ID. After, used the ExpressionEvaluator to calculate _result ( @Value(DEMAND)*@Value(PATTERN) ).
At last the transformer Aggregator by Zone.
Thanks,
Danilo - -total-demand.fmwt
erik_jan
  • August 14, 2017
Hi @amitaman001
After re-reading it should be the other way around:
Do the FeatureMerger to join, then the StatisticsCalculater and group by on ZONE.
  • August 14, 2017
select
    a.ZONE,
from DBF2 as a
group by a.ZONE
  • August 15, 2017
select
    a.ZONE,
from DBF2 as a
group by a.ZONE
Thanks !
It works perfect !
