WordWrapper 2.0?
  • Nov 28, 2016 3:58 PM UTC
  • 14 replies
  • 112 views
peteralstorp
Forum|alt.badge.img+8
Hi, I need an easy way to split a string at a desired lengt, but I want to avoid splitting words. There once was a WordWrapper but it's not working anymore. Any suggestions?
Best answer by david_r
I posted this a long time ago, but it's not easily searchable and the code has been mangled while ported between the different versions of the forum software, so here's a slightly modified version of my original post.
You can insert the following code into a PythonCaller, it will read a string from the attribute "text_line_data" and wrap it at the position specified in a parameter "MaxWidth":
import fmeobjects
import textwrap
def TextWrapper(feature):
    text = feature.getAttribute("text_line_data") # modify as necessary
    maxLength = int(FME_MacroValues['MaxWidth'])
    parts = textwrap.wrap(text, maxLength)
    feature.setAttribute('number_of_parts', len(parts))
    if parts:
        feature.setAttribute('parts{}', parts)
Expose the attributes "parts{}" and "number_of_parts" in the PythonCaller.
This outputs all parts to the list "parts{}", you can then use a ListExploder to get one feature per wrapped line, see attached sample workspace.
textwrapper.fmwt
fmelizard
Forum|alt.badge.img+22
  • Nov 28, 2016 4:14 PM UTC
It seem you need "SubstringExtractor" transformer.
  • Nov 28, 2016 4:17 PM UTC
import fmeobjects
import textwrap
    if parts:
textwrapper.fmwt
peteralstorp
  • Nov 28, 2016 4:26 PM UTC
import fmeobjects
import textwrap
    if parts:
textwrapper.fmwt
Blessed be the force of the Knowledge center! Thank you, David!
mark2atsafe
Forum|alt.badge.img+59
fyi I filed a request to get the WordWrapper fixed. It's PR#74183
  • Nov 28, 2016 4:34 PM UTC
That's good to hear. Feel free to borrow bits of the code below if you decide to port it to Python.
itay
Forum|alt.badge.img+19
  • Nov 28, 2016 5:02 PM UTC
It still there on the FME hub
  • Nov 28, 2016 5:03 PM UTC
Yes, but it doesn't work (as it should) in FME 2016.
rylanatsafe
Forum|alt.badge.img+14
import fmeobjects
import textwrap
    if parts:
textwrapper.fmwt
@david_r - Fantastic! I'm glad to see that you have found a fix for this custom transformer! This would be a major change in the behind-the-scenes functionality from when it was first created (and last updated) in FME 2012.
I would like to encourage you to submit this as a new custom transformer to FME Hub, e.g. TextWrapper, and we can deprecate the WordWrapper.
  • Nov 29, 2016 3:38 AM UTC
Maybe this update works with FME 2016.1.3: b16709-wordwrapper-v2-beta.fmw
Hi @DanAtSafe, please update the WordWrapper in the Hub.
  • Nov 29, 2016 4:32 AM UTC
oops, I overlooked @Mark2AtSafe's comment. Good to hear that the request has been filed already.
  • Nov 29, 2016 8:41 AM UTC
Done: https://hub.safe.com/transformers/textwrapper
Let me know if anything is unclear.
peteralstorp
  • Nov 29, 2016 9:52 AM UTC
Perfect, will definately use the wrapper sometime again soon. Thanks!
fme4ever
  • Apr 20, 2022 2:15 PM UTC
import fmeobjects
import textwrap
    if parts:
textwrapper.fmwt
Awesome! This one worked like a charm, thanks!! 😁
  • Apr 20, 2022 3:32 PM UTC
Thanks for the feedback and the push to fix the formatting one more time :-)
