why polygon attribute from dgn has no output of inspector
  • Jan 24, 2020 3:36 PM UTC
  • 74 views
gogopotter90
Forum|alt.badge.img+14
as you see in photo no amount of numbers get out of polygon so i will not see anything if i connect the polygon with inspector so what should i do ,both of them get from the same file,is that normal or there is transformer should i add before work on it .thanks
but if click inspect on polygon it hows me in display control,ellipses and lines and multi text and points and shapes and text .
but if i create inspector and connect with polygon it shows nothing,it does not give me the fme data inspector to see how it looks like ,what is important for me i want to find intersecton between lines and polygon but lines show me amount of numbers on output but polygon show nothing so the ouput is wrong .i hope,i find answer.thanks
erik_jan
Forum|alt.badge.img+26
  • Jan 24, 2020 4:35 PM UTC
How did you create the Polygon feature type?
It does not seem to be in line with the lines feature type (FME is case sensitive).
The documentation for the DGN v7 reader is available here
gogopotter90
  • Jan 24, 2020 5:06 PM UTC
this the original photo what i got from dgn file ,i need to use polygon and line to et intersection but output of polygon does not appear or amount of number does not show ,only lines that i can i see on inspector
erik_jan
  • Jan 24, 2020 5:12 PM UTC
Have you tried opening the file in the Data Inspector to see what data FME is retrieving?
Or could you share the file here, so we can have a look?
gogopotter90
  • Jan 26, 2020 4:37 AM UTC
i did it .thanks alot for help
