This is my 1st time to use UPDATEDETECTOR to compare the changes in an Oracle SDE feature class and update it accordingly. Very simple process. The same SDE feature class is both the original and the writer. The feature class is initially empty. The first run works correctly to insert 75 features. I would expect the 2nd run to do nothing, but it still finds 75 updates and writes to the feature class. I have only have 2 attributes to match against, the key attribute, and a number attribute. I also tried on a Date attribute to match against, the same result. See attached. Anything I did wrong?
Why my UpdateDetector does not work?
Best answer by erik_jan
Have you tried rounding the coordinates of both datasets before comparing the geometries? You can use the CoordinateRounder to do so (e.g. round to 3 decimals). The Reader and or Writer can add decimals up to 10 digits behind the decimal point caused by number conversions.
