Why is the position being moved after transforming the point cloud into the Mesh
  • May 26, 2023 5:04 PM UTC
  • 30 views
Hi, i am using this structure to generate solid meshes from a LAS, extruding the point from x,y and z and then building the mesh of each small cube.
But I found that the solid mesh was moved in the space (there is an offset) when I use cloud compare to viz it, and I don't know why it is occurred.
LAS before and Solid afterPointcloud_mesh_loopVery grateful for the answer!!
thanks:) !
JennaKAtSafe
Forum|alt.badge.img+9
Hi @fdh12316​ is there a coordinate system that is set in the original las?
