Why is the area with value 0 not preserved as is when using the sliverremover with priority 0,1,2?
  • Aug 3, 2016 2:26 PM UTC
  • 35 views
The sliverremover transformer is configured with priority setting 0,1,2 for different areas. Idea was to keep area with the value 0 unchanged after running the workspace. But this is not the case. value 0 is also changed in some occasions. How can I be shure to keep the areas with this value untouched?
erik_jan
Forum|alt.badge.img+26
  • Aug 3, 2016 2:41 PM UTC
Can you use a Tester in front of the SliverRemover to filter out the priority 0 and bypass the SliverRemover?
