Why does the Anchorsnapper not snap to all anchor points?
  • September 13, 2017
  • 6 replies
  • 153 views
I have two point featureclasses and want to snap the points from Point_01 to Point_02. Both Featureclasses have 261 points, but after the translation, there is always only 245 snapped points and 16 which are untouched. I have tried many tolerances and snap-to-Vertex as well as snap-to-endpoints, but something is stopping the 16 points from snapping to the next point.
If anyone can shed some light I would be most grateful
Best answer by david_r
Could it be that 16 of the points in "Point_01" already superposes a point in "Point_02"?
Forum|alt.badge.img+63
If you inspect the untouched points in relation to the anchors, do they fall within the tolerance? Any other odd things?
If you can share your data it would help us find out what's going on.
nielsgerrits
Forum|alt.badge.img+67
My bet is on this.
It's the most likely situation.
Correct...I did not expect to have points which shared the same coordinate. Thanks
FYI. You can simply check if each Untouched point exactly match an anchor point, using the SpatialFilter (Anchor -> Filter, Untouched -> Candidate).
