Why does regular expression not work in BulkAttributeRemover?
The regular expression input for bulkremover works if I type in:
    fme_.*
But if I try to add another expression using the regex or it fails to recognize the regex statement
     fme__.*|igds_.*
I tested this statement using the ruby testing aplication recommended in the help section, and it was able to recognize the statement
  • April 10, 2014
it seems you have two underscores after "fme" in the second statement, is that on purpose?
David
  • April 11, 2014
Indeed. The current BulkAttributeRemover seems not to support some complex regular expression. In this case, you can use two BulkAttributeRemover in series.
1st: fme_.*
2nd: igds_.*
Takashi
gio
Forum|alt.badge.img+15
  • April 11, 2014
In the stringsearcher it works.
I tried it in the bulkatt.rem.
I confirm it does not accept "pipelines". Only single line expressions. Nothing helps, braces, brackets..to no avail.
Pretty limited it seems.
You wil have to use 2 Bulkremovers in sequence to remove 2 attributes in bulk using a regexp.
Gio
gio
  • April 11, 2014
also the regexp works, it seems the bulkremover does nothing with the result.
