Why do some lines not have vertices?
  • Mar 7, 2018 8:52 PM UTC
  • 51 views
Hello,
I have a quick question. I'm joining lines together based on their nearest point, however not all lines have vertices and as a result the line will not extend. Why is this? I would think there would be a starting and ending node. See image below. (red and blue dots are vertices. Arrow pointing to where vertices do not exist.)
Is there a way to add a point to the end/start of a line? Densifier transformer did not seem to work.
Thanks,
David
fmelizard
Forum|alt.badge.img+22
  • Mar 7, 2018 10:34 PM UTC
Hi @david_prosack88 Check the line with a GeometryValidator and also look at the geometry with a Logger or the Data Inspector. You can add coordinates to lines with the VertexCreator.
