Where is Syntax Highlighting option in advanced text editor ?
  • Sep 8, 2020 3:26 PM UTC
  • 100 views
rlagarde
Documentation mention 'Syntax Highlighting' as an option in the advanced text editor.
Is it possible to set the highlighting scheme to a given language (SQL) from a stringConcatenator transformer?
Best answer by david_r
It seems you are using the StringConcatenator, which does not support syntax highlighting.
Consider using e.g. the AttributeCreator to concatenate the string instead, the editor there supports syntax highlighting.
  • Sep 8, 2020 3:50 PM UTC
In the advanced editor, there is a button "Options" in the bottom left hand corner of the dialog. The first choice is "Syntax Highlighting", where you can select, amonst other things, SQL.
rlagarde
  • Sep 9, 2020 6:35 AM UTC
Thank you for answering, I tried in FME 2017, 2019 and 2020 but I don't see it.
Could it be license related?
fme_sh
  • Sep 9, 2020 7:45 AM UTC
rlagarde
  • Sep 9, 2020 7:51 AM UTC
Thanks
