Where can I find the records that were dropped because they snapped into a single point in snapper
  • Jan 23, 2018 2:36 PM UTC
  • 6 replies
  • 83 views
I have been running a script that uses snapper and get the following line in the log:
2018-01-23 08:08:01| 42.7| 0.0|WARN |Snapper(SnappingFactory): Processed 83703 feature(s). 10930 were snapped, 72770 were untouched, and 3 were dropped because they snapped into a single point
I have tried to find where FME lists the 3 dropped records, but have been unable to. Snapper only has Snapped and Untouched as output so I can't just add an inspector to it.
Forum|alt.badge.img+63
If you really want to see them you could use a ChangeDetector to compare the data before and after the Snapper.
Thank You. I was hoping for a log file that I couldn't find, but this will work.
erik_jan
Forum|alt.badge.img+26
  • Jan 23, 2018 4:38 PM UTC
It would make a great idea to add an output port for the "Dropped features".
I would vote for that.
jdh
Forum|alt.badge.img+41
  • Jan 23, 2018 8:35 PM UTC
Agreed, but it would have to be on a key attribute only, because there will be a lot of geometric changes due to the snapping.
fmelizard
Forum|alt.badge.img+22
  • Jan 23, 2018 8:55 PM UTC
Hi @linasvebeliunas, the Snapper in our FME 2018 betas has a Collapsed port. See the documentation for more information.
If a line or area feature snaps down to a single location, it will be output as a Point geometry, through the Collapsed port.
erik_jan
  • Jan 23, 2018 9:38 PM UTC
And again Safe is one (beta) step ahead of us.
