When writing FME DateTime to ESRI FGDB How can I retain midnight times?
  • Oct 9, 2019 2:38 PM UTC
  • 7 replies
  • 251 views
rob_m_esriuk
I have a workbench which builds FME date time attributes and writes them to ESRI FGDB Classes. So, for 20191009115225 I get 09/10/2019 11:52:25 however if the time is midnight the fme date is 20191009000000 and the FGDB field contains 09/10/2019. How do I get this field to retain the 00:00:00 values?
Best answer by mark2atsafe
So... it appears to be a known limitation that 00:00:00 in Geodatabase represents "no time". So I don't think it's going to be possible to retain a meaningful midnight value!
I don't think it supports fractions of a second either, so the best you could do is add a second to make it 00:00:01, using the DateTimeCalculator transformer.
rob_m_esriuk
Using FME 2018.1
rob_m_esriuk
  • Oct 15, 2019 3:37 PM UTC
I suspect this is a feature of ArcCatalog and the 00:00:00 is just not displayed!
erik_jan
Forum|alt.badge.img+26
  • Oct 15, 2019 3:53 PM UTC
If you want to be sure FME is writing the midnight time, run the workspace with "Redirect to FME Data Inpsector" (under the writers menu) turned on.
FME will write to the Data Inspector instead of to the database, so you can check the data before the writing.
That will allow you to see what is actually written, before ArcCatalog is displaying it and will allow you to see if the 00:00:00 is written.
mark2atsafe
Forum|alt.badge.img+59
I'm not so sure about that. I just tried it, read it back with FME, and the time was missing. I think this might be our issue. I'll check with our developers and get back to you. Are you using the full geodatabase writer or the open API one? It was the API one I tried.
mark2atsafe
  • Oct 16, 2019 9:22 PM UTC
rob_m_esriuk
  • Oct 17, 2019 7:21 AM UTC
I did try fractions of a second and they just disappeared too :) We can live with this as we want the date times in sequence and this will still sort correctly . Eventually we are going directly to Arcgis Online, I will check what happens there as soon as I can
Forum|alt.badge.img+54
  • Oct 17, 2019 7:58 AM UTC
It's an ESRI thing rather than FME. Try and set the time to 00:00:00 directly within the GDB and you won't see the 00:00:00 displayed. It assumes a midnight time if one isn't shown, e.g. if you query for = timestamp '2019-10-09 00:00:00' it will display those records where 00:00:00 isn't displayed
