When I write dgn file in FME, my original added line style changes. How can I save it?
  • Sep 21, 2020 1:56 PM UTC
  • 56 views
naste4kina
Here is my original file. I made my own line style for different objects.1
Then I make the simplest transformation with FME and it saves my line style.
2
and then I write dgn file and in it, I see another line style.3
in some cases I can see one of default line styles, but sometimes it uses my added style but not that one, that I used before FME
xilef
Forum|alt.badge.img+5
  • Sep 21, 2020 5:44 PM UTC
Hello @naste4kina​ , you could use the DGNStyler transformer or altenatively the parameters in the DGN Writer feature type to specify the specific line style that you want. It is possible that the writer used a default style for these features.LineStyleDGN
muzhnasto
Forum|alt.badge.img+12
  • Sep 22, 2020 8:03 AM UTC
Hi I met with a similar problem. Can you explain in more detail?
chrisatsafe
Hi @muzhnasto​ - this article might come in handy as it goes into greater detail regarding the DGNStyler.
