What's up with the change to the Python API for nulls in Build 14252?
  • February 24, 2014
  • 6 replies
  • 104 views
fmelizard
Forum|alt.badge.img+22
Hi everyone,
Build 14252 (http://downloads.safe.com.s3.amazonaws.com/fme/beta/whatsnew_sp.txt) included this changelist:
  “Python API change: getAttribute() and getTrait() now return empty strings, rather than None, for null values.  (PR#51278)”
Why was this API change introduced?
Takashi helped us discover, in his blog article (http://fme-memorandum-takashi.blogspot.ca/2014/01/efficiency-of-list-attribute.html), an unintended inconsistency in our Python API. FME 2014 has added support for null values through its FME Objects APIs. Support is added both for features and geometries. Existing API methods and functions that wrap around the string versions of getAttribute() and getTrait() from the FME core return empty strings for nulls, as intended.
All APIs appear to behave this way in FME 2014 except the Python API. Therefore, we made the Python API consistent with the other APIs as part of FME 2014 SP1. We have recorded this intended behavior in the section “FME Objects” here (http://fmepedia.safe.com/articles/FAQ/How-does-FME-handle-Null-attribute-values#heading_toc_j_7).
Finally, if you are a plug-in developer, you might be interested in reading FME 2014 Null Porting Guide For Plug-ins (http://fmepedia.safe.com/articles/How_To/FME-2014-Null-Porting-Guide-for-Plug-ins). Users of PythonCaller, TCLCaller, and FME Objects may also find portions of this guide useful.
  • February 25, 2014
thanks for this information, very helpful. Always good to know about these things before they become an issue.
Now, if you could just implement the raster classes as well in the Python API, and I'll be very happy :-)
David
  • February 25, 2014
Hi Tai,
Thank you for the announcement. I believe those documentations would be helpful to all of us.
I also will be happy if there were Python classes for raster and point cloud :)
Takashi
  • February 25, 2014
@Takashi,
thanks to this posting I just found your blog. Great stuff, keep it up :-)
David
  • February 25, 2014
Hi David and Takashi,
Tai asked me to deal with your additional requests for Raster and Point Cloud classes within the APIs. So I have created a case for each of you in our support system and added you to a variety of PRs relating to Raster and Pointcloud availability and so you will be notified via the usual process when (and if) they become available.
If you are interested the PR#s are
PR#50880 - Raster objects needed in Python API
PR#17880 - FME Objects Java wrappers: Update raster interfaces
PR#30785 - FME Objects Wrappers: Add PointCloud classes and methods
Cheers,
Robyn Rennie
FME Desktop Support
  • February 26, 2014
Hi Tai and Robyn,
Thank you for the quick response.
FME + Python can solve difficulties which we cannot solve with existing transformers only, any enhancement to Python API will bring us big benefits.
Thanks in advance.
Takashi
  • February 26, 2014
Thanks Robyn, much appreciated!
I look forward to doing lots of cool stuff with the new fmeobjects raster API.
David
