What is the best way to find the maximum value of an attribute given 3 other constraining attributes?
  • Oct 19, 2023 1:53 AM UTC
  • 52 views
daniel.m.getz
Forum|alt.badge.img+4
I have data coming in from an instrument. It contains the readings for gasses like oxygen and H2S.
I am trying to create a report to highlight the highest value in a given hour on a given day. With the table below:
Instrument 1 | 10:00 AM | March 1st | Unit ABC 123 | H2S 10 ppm
Instrument 1 | 10:05 AM | March 1st | Unit ABC 123 | H2S 5 ppm
Instrument 1 | 10:10 AM | March 1st | Unit ABC 123 | H2S 0 ppm
Instrument 1 | 10:00 AM | March 2nd | Unit ABC 123 | H2S 10 ppm
Instrument 1 | 10:05 AM | March 2nd | Unit ABC 123 | H2S 15 ppm
I would want the report to show me the following,
because those values are the highest gas reading for each hour, (10 AM as a record, 11 AM as another etc) on each unique day.
I have tried the statistics calculator, but it doesn't allow you to accumulate the other attributes, or allow you to find unique fields to 're-merge' the data together. I am suspect that it is returning the expected data.
Am I missing an obvious transformer to use here?
Best answer by geomancer
What a truly terrible format...
Anyhow, the Complete port from a StatisticsCalculator, followed by a TestFilter, should do the trick.
geomancer
Forum|alt.badge.img+71
  • Oct 19, 2023 9:14 AM UTC
