What is the best way to check that data points are a certain distance apart?
  • Jan 25, 2023 10:29 PM UTC
  • 134 views
I am trying to automate some quality tests & I need to calculate the distance between the points in a consecutive manner. So, each point needs to be  '50-100 feet' apart from its previous point. I am unsure which transformer(s) would be the most efficient & haven't had much luck looking online. Thanks!
nielsgerrits
Forum|alt.badge.img+67
I think this is a polyline / polygon dataset? One way to do this is to chop the features to lines with two vertexes using a Chopper and calculate the line lenght using a LengthCalculator.
dustin
Forum|alt.badge.img+36
  • Jan 26, 2023 10:45 AM UTC
I think we need more specifics to give an exact answer, but I wanted to give the solution a shot because I thought it was interesting challenge. I'm assuming when you say previous point that you mean there is a consecutively numbered attribute such as ObjectID in the example below. If so:
  • Use an AttributeManager to extract the previous ObjectID in a copy of the points in a new attribute previous_ObjectID
  • Use an AttributeRenamer to rename previous_ObjectID to ObjectID
  • Feed these features along with the original features into a LineBuilder
  • In the LineBuilder, set the Group By processing to ObjectID
  • Use LengthCalculator to get the distance between consecutive points
  • From there you could use a Tester or TestFilter to find those lines (distances) less than your tolerance.
@travis34​ "a picture is worth a thousand words" (F. Barnard). A small sample dataset is worth a thousand pictures (annon.) If you can attach a small sample dataset someone might be able to piece together a proof-of-concept
