What causes my attribute values (in this case CASnumbers) to be distinct?
  • Oct 6, 2022 4:55 PM UTC
  • 5 replies
  • 82 views
thijsknapen
Forum|alt.badge.img+12
I encountered something peculiar last week. I had to compare two datasets about chemical substances measured in groundwater.
To compare the datasets, I used the ChangeDetector. While doing so, for one substance an update/change was found for the value of a CASnumber. However, when I look at the originalValue and the revisedValue, I don't see any difference. Also, when I perform a compare using (a plugin of) Notepad++, it also detects a difference in the two CASnumbers. So there seems to be a difference, I just can't seem to spot the difference ;)
Maybe some people here can help take a look and provide an explanation?
Any feedback is appreciated.
The CASnumbers are:
CASnumber_1 = '‎483-63-6'
CASnumber_2 = '483-63-6'
See also the screenshots below for a dummy workspace and the comparison using (a plugin of) Notepad++;
Best answer by geomancer
Because they're different 😁 : CASnumber_1 contains some invisible character in front of the 4.
Saving the value of CASnumber_1 to a text file gives a file of 11 bytes. CASnumber_2 results in a text file of 8 bytes.
Comparing both files in PowerShell gives:
CASnumber_compareIn the AttributeCreator, you can go to the start of CASnumber_1 and press Delete once. This will not visually change the value, but afterwards the TestFilter will indicate both values are equal.
geomancer
Forum|alt.badge.img+71
  • Oct 7, 2022 7:09 AM UTC
thijsknapen
  • Oct 7, 2022 7:43 AM UTC
Thanks!
That indeed explains. I guess invisible characters are not always easy to spot ;)
I opened my sample workspace in NotePad++, and also found a similar observation;
<XFORM_PARM PARM_NAME="ATTR_TABLE" PARM_VALUE="&quot;&quot; CASnumber_1 SET_TO &lt;u200e&gt;483-63-6 CASnumber_2 SET_TO 483-63-6"/>
geomancer
  • Oct 7, 2022 7:50 AM UTC
Nice find!
U200E is the Left-To-Right Mark, which of course is an invisible character.
Makes one wonder why it's there...
thijsknapen
  • Oct 7, 2022 8:10 AM UTC
Nice find!
Yeah, I also found that. And &lt; is xml encoding of '<' (less than), and &gt; is xml encoding of '>' (greater than). So to me it seems like 3 characters, but maybe the '<' and '>' are stored/read as a kind of header/declaration, i guess a as kind of wrapper around the Left To Right Mark.
I also don't know why it's there in my dataset, but that's a different question :|
Thanks again for helping me spot it 🙂
First thing is knowing what's up, second thing is how to deal with it ;)
geomancer
  • Oct 7, 2022 8:14 AM UTC
Nice find!
You're most welcome!
