WARNING & TIP! %Y%m%d%H%M%S Date/Time values in CSVs are NOT the same as FME Date/Time (%Y%m%d%H%M%S)!
  • Apr 7, 2017 11:49 AM UTC
  • 13 replies
  • 113 views
tim_wood
Forum|alt.badge.img+8
I have CSV files with dates in the format %Y%m%d%H%M%S e.g.
Mobile Inspection,Cancelled,20140905151941,20141107130117
I'm using the CSV2 Reader in FME 2017.1 (17271) and reading in all CSV attributes as string.
In DateFormatter, if I set my Source Date Format to FME Date/Time (%Y%m%d%H%M%S) and my Destination Date Format is %d/%m/%Y %T (I've also tried %d"/"%m"/"%Y" "%T), all I get is the Invalid Date value.
However, if I set my Source Date Format to %Y%m%d%H%M%S and my Destination Date Format is %d/%m/%Y %T it works!
So even though you might think FME Date/Time (%Y%m%d%H%M%S) and %Y%m%d%H%M%S are equivalent, they're not (at least not when reading CSVs).
Best answer by takashi
I think the format "FME Date/Time (%Y%m%d%H%M%S)" for source date matches "FME Date/Time (20140905151941)", for example. That is, "FME Data/Time" and the round brackets would be interpreted as parts of the format literally.
  • Apr 7, 2017 12:06 PM UTC
  • Apr 7, 2017 12:07 PM UTC
Not sure what you're doing, I'm unable to reproduce:
Result:
Attribute(encoded: utf-8)         : `TS1' has value `2014-09-05'
Attribute(encoded: utf-8)         : `TS2' has value `2014-11-07'
tim_wood
  • Apr 7, 2017 12:09 PM UTC
Are the date values in your CSV quoted or un-quoted?
Ah yes, this won't work:
Whereas this works:
  • Apr 7, 2017 12:15 PM UTC
The CSV I used was copy-pasted from this post, I simply added a header with some field names:
tim_wood
  • Apr 7, 2017 12:19 PM UTC
Here's a test file and FMW that demonstrates the problem...
  • Apr 7, 2017 12:22 PM UTC
There's your error:
See also the comment I posted under Takashi's answer.
As it is, FME would expect your CSV to contain the following:
  • Apr 7, 2017 12:30 PM UTC
There's your error:
I'll just add this: if you think this is rather confusing behavior from the DateFormatter, them I'm totally with you :-)
tim_wood
  • Apr 7, 2017 12:33 PM UTC
The crucial piece of information I didn't include was that I copied & pasted FME Date/Time (%Y%m%d%H%M%S) from the Destination Date Format box because it doesn't appear in the drop-down list in the Source Date Format box.
  • Apr 7, 2017 12:35 PM UTC
Yup, and personally I think that the DateFormatter could be a bit more intelligent about it, the current behavior isn't consistent and potentially confusing. I'll let you suggest an idea to improve it :-)
tim_wood
  • Apr 7, 2017 1:04 PM UTC
There's your error:
Agreed. The only option in the Source Date Format is unknown - automatic detection hence my copy and paste. Does anybody ever get anything else? If not I'll post an idea to add the usual date/time format options to the list.
  • Apr 7, 2017 1:06 PM UTC
No, there are no other items in that list (that I know of). A good candidate for improvement.
tim_wood
  • Apr 7, 2017 2:42 PM UTC
