Vincenty's formula inverse
  • Mar 26, 2014 1:40 PM UTC
  • 61 views
Hi
I seeking a way on how to use the Vincenty's inverse formula (or any other solution) within FME. I got several hundreds of ascii files of sub bottom seismic data that i need to process. Each file can contain many millions of rows, i.e. points. The vast amount of data requires the solution to be non-geographical, only to be solved with mathematics.
What I need to do is to calculate and check the distances between point locations (the rows) as well as compare height differences (z) between the pairs;
Row2 to Row1
Row3 to Row2
Row(n) to Row(n-1)
I cannot find a way on how to first store one row in memory and then compare it with a previous row. If the difference in height or length is too far off I need to mathematically give Row(n) a new position based on the first and shot point index
Any suggestions on how to get around this problem is most appreciated
  • Mar 26, 2014 2:13 PM UTC
look into the AttributeCreator, in FME 2014 it will allow you to reference attribute values from both prior and subsequent features:
There is more info in the Help.
David
  • Mar 26, 2014 2:43 PM UTC
Great, thanks.. i didn't know that this functionality existed..
André
